DeepCool Launches Mini-ITX Case with Carrying Handle, Mesh All Around
Image: DeepCool
DeepCool has listed the CH160, a new mini-ITX case that delivers not only portability and style via its small footprint, but also mesh panels on most sides, enabling greater airflow. This case can fit GPUs of up to 305 mm in length, as well as air coolers that are up to 172 mm in height.
Product links:
Technical specs:
Image: DeepCool
A promo video:
A gallery for the black version:
DeepCool on its new case:
CH160 case expands DeepCool’s case line to the SFF category while keeping all the hallmarks found in the existing airflow case models. With GPU direct installation compatibility, there’s no need for an additional riser cable, reducing latency. Its generously sized air cooler accommodation and densely perforated front panel ensure optimal system cooling at all times.
