The Razer Facial Interface and Razer Adjustable Head Strap System for Meta Quest 3, a new system from Razer that merges the company’s cutting-edge technology with the needs of the modern VR gamer, is now available from Razer.com, Meta.com, and other authorized resellers for $69.99, Razer has announced. It joins Razer’s existing lineup of products for the Meta Quest, including the Razer Hammerhead HyperSpeed for Meta Quest 3, wireless earbuds that feature support for ultra-fast 2.4 GHz, cross-platform compatibility, and Bluetooth 5.2.
Product/store links:
Tech specs:
- Razer Adjustable Head Strap System
- Length: 215 mm / 8.46″
- Width: 200 mm / 7.87″
- Height: 175 mm / 6.88″
- Weight: 70 g / 0.15 lbs
- Straps: Nylon Textiel Laminate
- Clips: Polycarbonate ABS
- Razer Facial Interface
- Length: 170 mm / 6.69″
- Width: 115 mm / 4.52″
- Height: 110 mm / 4.33″
- Weight: 90 g / 0.2 lbs
- Cushion: Silicone, Foam
- Chassis: Polycarbonate
A look at its compatibility with the Meta Quest 3 charging dock:
Razer on its new hardware:
The Facial Interface now cleverly adapts to the Meta Quest 3 charging dock, allowing for effortless mounting and charging. But the real magic lies in the ultra-thin textured membranes of the facial interface, designed to distribute weight evenly and reduce pressure points, ensuring you can stay in the game longer without discomfort.
We believe that the materials used in VR accessories are just as important as the technology powering them. That’s why we chose hypoallergenic silicone free from latex and PU/TPE additives for the facial interface.
Recognizing the diversity within our gaming community, we meticulously calculated the ideal vector and angle for each strap of our Adjustable Head Strap System, ensuring a great fit for any gamer. Our goal was to create a product that is as inclusive as it is innovative, accommodating all head shapes and sizes with minimal force and maximum comfort.
Selecting the right materials was crucial not only for comfort but also for durability. The Adjustable Head Strap System is crafted from high-performance nylon, balancing comfort with the resilience needed for prolonged use.
